To connect to Web MV
For example, if you choose the default virtual directory name AP, and the name of the CA Automation Point server machine is appgh1, the following URL launches Web MV from a remote Web browser:
http://appgh1/AP/WebmvGUI.html
The home page of the Web MV GUI displays.
Important! You must have internet access to download the JRE.
Note: During the installation of the JRE, the Java Plug-in is set as the default Java runtime for your web browser. You can remove this default setting by using the Java Plug-in Control Panel.
After you have connected to a CA Automation Point server, the Web MV main window displays.
