Use the Permission Level field in your global or local session definitions to specify access permissions for a session. You can apply this setting to all defined sessions or to a specific session.
The following levels of access permissions are available:
All users can view the session, but they cannot issue commands.
All users can view the session and issue commands through the command dialog.
All users are granted FULL access and can issue commands directly through the session.
No users are granted remote access.
The level of access is based on the user's permission level for a file that you specify.
Note: To set this level of access, in Configuration Manager, navigate to Expert Interface, Automation, Remote Viewing, Remote User Login Security, and make sure that Windows Security is selected.
To allow only one user at a time to control a session, you can enable Primary Control Mode. For more information, see Primary Control Mode.
