Previous Topic: Specifying KeystrokesNext Topic: Operation Instructions
Key Abbreviations
A key abbreviation consists of the @ character followed by an alphabetic letter (uppercase or lowercase), a digit, or the character itself. For example, the abbreviation for the Enter key is @E. The abbreviations are mnemonic; that is, they correspond as much as possible to the actual name of the key. For example, @C is the abbreviation for the Clear key, @A is the abbreviation for the Alt key, and so on. The following table provides a comprehensive list of valid key abbreviations.
Note: When you press a shift key (such as Alt) in combination with another key, the meaning of that key changes. For example, the Alt+Clear keys constitute the Test key; to send the Test keystroke, type @A@C.
The following is a list of key abbreviations.
Abbrev.
For Key
Abbrev.
For Key
Abbrev.
For Key
@u
PageUp
@PgUp
@v
PageDown
@PgDn
@A
ALT
@V
Cursor Down
@c
PF12
@B
Backtab
@X
Reserved
@d
PF13
@C
CLEAR
@Z
Cursor Right
@e
PF14
@D
Delete
@ character
@f
PF15
@E
ENTER
@0
Home
@g
PF16
@F
Erase EOF
@1
PF1
@h
PF17
@H
Help
@2
PF2
@i
PF18
@I
Insert
@3
PF3
@j
PF19
@K
Copy
@4
PF4
@k
PF20
@L
Cursor Left
@5
PF5
@l
PF21
@N
New Line
@6
PA6
@m
PF22
@Q
Finish (Quit)
@7
PF7
@n
PF23
@R
Reset
@8
PF8
@o
PF24
@S
Shift
@9
PF9
@x
PA1
@T
Tab
@a
PF10
@y
PA2
@U
Cursor Up
@b
PF11
@z
PA3
