CA Automation Point provides you with the following applications for configuring and viewing managed sessions from a remote workstation:
Extends the CA Automation Point real-time console emulation to a remote Windows workstation.
Allows you to remotely access and view a recent history of messages received and processed by CA Automation Point using a Web browser.
The Web Message Viewer provides you with a line-by-line interpretation of the messages received by CA Automation Point, not exact console emulation. However, the Web Message Viewer allows you to change the visual attributes of the messages and view messages that have scrolled off the screen.
Although the Remote Viewer and Web Message Viewer are both remote viewing applications, they perform different functions, as described in the following sections.
