Previous Topic: Updating Notification PoliciesNext Topic: New CA-Supplied NM Policy Definitions Not Included
Troubleshooting the Notification Website
This section contains hints and tips about using the Notification Website.
Notifications Not Updated
Symptom:
I made a schedule change for a contact (added, changed, or deleted a schedule entry). Why didn’t Notification Manager initiate notifications according to the updated schedule?
Solution:
The modifications to the contact were not saved. If you clicked OK after you added, changed, or deleted a schedule entry, the local copy of the schedule was refreshed, and you can see the updated schedule. However, you must click Commit to save the changes to the Notification Manager database. The Notification Website notifies contacts according to schedules that have been "committed" or saved in the Notification Manager database.
Methods Not Updated
Symptom:
I modified the parameter definitions for a method (added, changed, or deleted a parameter). Why didn’t Notification Manager issue notifications using the updated method parameter definitions?
Solution:
The method modifications were not saved. You must click Commit to save the changes to the Notification Manager database. See the answer to the previous question for an explanation.
Notification Failure
Symptom:
I sent a notification to a contact that the Notification Website indicated was available. Why did the notification fail with an RC=6178?
Solution:
The contact schedule displayed is the active schedule as of the time you logged on to the Notification Website. If subsequent changes are made to the schedule, and a send notification is initiated, the contact is notified according to the currently active schedule. If no methods are defined for the current time, then the notification will fail with an RC=6178. To view the current contact schedule before sending a notification, log off and then log back on to the Notification Website. Jump to the Notify page and reselect the contact.
REXX Program Not Included in Invocation List
Symptom:
I created a REXX program in the site\myfiles\rexx directory to be invoked by a Notification Manager method. When I create or modify a method from the Notification Website, why doesn’t the Notification Website include the new REXX program in the list of possible invocation programs?
Solution:
The list of invocation programs displayed from the Notification Website is the list of programs available as of the time you logged on to the Notification Website. If the REXX program was created after you logged on to the Notification Website, it will not be listed. To view the current list of invocation programs, log off and then log back on to the Notification Website. Jump to either Create Methods or Modify Methods and re-select the invocation program.
