Managing Sessions Using CA Automation Point Windows › Using the Automation Point Desktop › Layouts › Active Layout
Active Layout
The optional SCREEN_SAVE and SCREEN_LOAD key operations use the active layout from which to save to or load layout information. The active layout is set by the following actions:
- When you specify the /l layout_name command line option. If this command is omitted, CA Automation Point uses the default value specific to the application
- When you save or load a layout or when you rename the current active layout from the Layouts dialog
Note: When the active layout is set to *Empty*, SCREEN_SAVE and SCREEN_LOAD operations do not perform any actions.
