Previous Topic: Using Pause ScriptsNext Topic: Creating a Script
Using Operator-initiated Scripts
From a command area, you can select the Start REXX program or script option to start a script manually. CA Automation Point asks for the name of the script file to execute. The specified script file executes in the session indicated by the command area. You can use operator-initiated scripts to execute predefined functions on command.
