Previous Topic: Sample Operation DefinitionsNext Topic: Associating a Scan Code File with a Session
Identifying Terminal Emulators
When you define a session to CA Automation Point the Terminal window attribute identifies the type of terminal emulator that you intend to use for the specified session. If you want to use the standard 3278 or 3279 terminal emulators, choose 3278 or 3279 from the list of terminals on the Automation Point Session Definition dialog.
Note: Define the terminal type and other session characteristics before starting CA Automation Point.
