Using the Plot Feature › Understanding the Plot Feature › Plotting a Graph
Plotting a Graph
To plot a graph showing system information, first set up a CA Automation Point window to display the graph. Choose PLOT as your window type in your function window definition.
After setting up a window from which to display the graph, you can plot the graph in one of these ways:
- Write a REXX program containing all of the PLOT command statements necessary for creating the graph. This method is the usual way to plot a graph.
- Use the Plot Feature with REXX.
- Create a menu to issue PLOT commands.
- Issue a series of PLOT commands from any of the CA Automation Point command entry points.
