Previous Topic: Key AS400MRP FunctionsNext Topic: AS/400 Default Logon Screen
AS400MRP Screen Examples
The following screen examples show a dialog initiated by AS400MRP.
MAIN AS/400 Main Menu System: S44A0060 Select one of the following: 1. User tasks 2. Office tasks 3. General system tasks 4. Files, libraries, and folders 5. Programming 6. Communications 7. Define or change the system 8. Problem handling 9. Display a menu 10. Information Assistant options 90. Sign off Selection or command ===> dspmsg msgq(*sysopr) msgtype(*inq) astlvl(*intermed) start(*last) F3=Exit F4=Prompt F9=Retrieve F12=Cancel F13=User support F23=Set initial menu
Display Messages System: S44A0060 Queue . . . . . : QSYSOPR Program . . . . : *DSPMSG Library . . . : QSYS Library . . . : Severity . . . : 40 Delivery . . . : *HOLD Type reply (if required), press Enter. Reply . . . _____________________________________________________ Load form type '*STD' device PRT02 writer PRT02. (H C G I R) Reply . . . _____________________________________________________ Record not added. Member MEMBERNAME is full. (C I) Reply . . : I Load form type '*STD' device PRT02 writer PRT02. (H C G I R) Reply . . : I Record not added. Member MEMBERNAME is full. (C I) Reply . . . i____________________________________________________ Load form type '*STD' device PRT02 writer PRT02. (H C G I R) Reply . . . _____________________________________________________ Record not added. Member MEMBERNAME is full. (C I) Reply . . . _____________________________________________________ Bottom F3=Exit F11=Remove a message F12=Cancel F13=Remove all F16=Remove all except unanswered F24=More keys
