Previous Topic: Local AS/400 System Non-Focal PointNext Topic: Remote AS/400 System
Local AS/400 System as an Alert Primary Focal Point
To have your AS/400 system work as an alert primary focal point for remote AS/400 systems, issue this command:
CHGNETA ALRSTS(*ON) ALRPRIFP(*YES) ALRLOGSTS(*ALL)
You need to explicitly define (in the local AS/400 system's sphere of control) the remote AS/400 systems that will send alerts. To do this, issue the WRKSOC command to add network node control point names. The Work with Sphere of Control screen displays; this screen shows the parameters for the WRKSOC command.
Work with Sphere of Control (SOC)
System: S44A0060 Position to . . . . . . . . Control Point Network ID . . . . . . . .
Type options, press Enter. 1=Add Control Opt Point Network ID Current Status *NETATR
(No entries in sphere of control) Bottom F3=Exit F4=Prompt F5=Refresh F9=Command F10=Display SOC status F11=Display new focal points F12=Cancel F16=Repeat position to
AS/400 Manager handles messages from a system that is set up as a primary alert focal point without any additional setup.
