To use the AS/400 Manager application, the AS/400 current system name and the AS/400 local control point name must be defined in OS/400 as the same name. Issue the OS/400 command DSPNETA to check whether the names match. A screen similar to the following displays:
Display Network Attributes
System: S44A0060 Current system name . . . . . . . . . . . . . . : S44A0060 Pending system name . . . . . . . . . . . . . . : Local network ID . . . . . . . . . . . . . . . . : APPN Local control point name . . . . . . . . . . . . : S44A0060 Default local location . . . . . . . . . . . . . : S44A0060 Default mode . . . . . . . . . . . . . . . . . . : BLANK APPN node type . . . . . . . . . . . . . . . . . : *NETNODE Maximum number of intermediate sessions . . . . : 200 Route addition resistance . . . . . . . . . . . : 128 Server network ID/control point name . . . . . . : *LCLNETID *ANY
More... Press Enter to continue. F3=Exit F12=Cancel
If a change is required, it is safer to change the AS/400 system name. To do so, issue the CHGNETA command and re-IPL the relevant AS/400 system.
