Interacting with External Event Systems › Using the CA NSM Interface › Troubleshooting the Event Traffic Controller › Sending Commands from Event Manager
Symptom:
How can I send commands from Event Manager to hosts that are managed by CA Automation Point?
Solution:
- From the Configuration Manager main window, choose Expert Interface, Automation, Events Interface, CA NSM Event Manager.
- Select the Monitor host command requests from CA NSM event.
- Check Enable Monitoring.
- Add the CA NSM host for which you want CA Automation Point to monitor host session command requests.
- Select the host by using the Include button to move it from the Available Hosts list to the Selected Hosts list.
- Click Host Access Security and then specify a valid login user ID and password for the remote CA NSM host.
- Save your changes.
- Restart CA Automation Point.
- On the CA NSM host, define an Event Manager message action to issue the command request to CA Automation Point.
