When an event is extracted from CA NSM, information about the event is available in the following CA Automation Point variables:
Specifies the time at which the event was generated.
Specifies the TCP/IP address of the device that sent the SNMP trap.
Specifies the value from the CA NSM Process field; this field normally contains the value ProcessID,ExecutableName.
Specifies the name of the host that generated the event.
Specifies the name of the CA NSM Event Manager host from whose log the event was extracted.
Specifies Error, Warning, Info, Success, or Failure.
Twenty bytes from the CA NSM Facility field are combined with twenty bytes from the Category field, resulting in a value of Facility,Category.
Specifies the entire message text associated with the event and the individual words of the message.
To monitor and process CA NSM Event Manager messages with CA Automation Point
The CA NSM Event Manager Events dialog displays.
Select the host by using the Include button to move it from the Available Hosts list to the Selected Hosts list.
Note: You can restrict the CA NSM messages that will be received and processed by highlighting the selected host and clicking the Filtering Criteria button.
MSGID(text that matches a CA NSM message) COLOR(RED)
