When an event is sent from CA Automation Point to CA NSM, information about the event is available in the following CA NSM fields:
Displays the message text associated with the event that was captured by CA Automation Point.
Displays the name of the CA Automation Point host that sent the event to CA NSM.
Displays the name of the CA Automation Point session in which the event occurred. You can override this value using the ORIGHOST operand on the UNIWTO or UNIWTOR command.
Displays a value of SNMP for SNMP traps; the value is Automation Point for all other events.
Displays the CA Automation Point component (UNICMD, UNIFWD, UNIWTO, or UNIWTOR) that sent the event.
Displays a value of E (error) when the event is a CA Automation Point action message; the value is I (information) for all other events. You can override this value using the SEVERITY operand on the UNIWTO or UNIWTOR command.
Displays the time at which the event was generated.
