Previous Topic: VOX Commands that Perform I/O OperationsNext Topic: Outbound Voice Notification with Input from Caller
Example VOX Environment Applications
This section presents REXX programs that employ voice commands. The programs illustrate the following application types:
Although the REXX code shown may vary slightly from the code on your distribution media, you can use the examples as a basis for writing your own voice processing applications.
Each example REXX program is presented in the same format. Each example contains these elements in the order listed:
