Previous Topic: Configuring Two-Way PagingNext Topic: The VOX Command Environment
Configure Two-Way Paging
To configure two-way paging
  1. From the main window of Configuration Manager, choose Expert Interface, Notification Services, Paging, 2-Way Paging, 2-Way Paging Setup.
    The 2-Way Paging Setup dialog displays.
  2. Click the Enable 2-way paging checkbox.
    This enables two-way paging inside the Notification Server, and allows you to start adding symbolic names of paging service providers.
  3. Right-click either the SNPP or WCTP provider tree and choose Add from the menu.
    For example, if you want to add a new paging service provider, and this paging service supports the SNPP communications protocol, right-click SNPP Providers and click Add.
    Note: For you to use the WCTP protocol, the paging service must support Version 1.1 of the WCTP protocol.
    A new item displays under either SNPP Providers or WCTP Providers, depending on which protocol type you have chosen.
  4. Enter a unique name for the provider.
  5. In the fields under Remote Connection Settings, configure your connection settings, using the dialog help to guide you.
    The connection fields that are contained within this group appear according to the connection protocol selected for the current provider.
    Note: The Paging Service Authentication button displays when you have added an item under the WCTP Provider section. If the application on the paging service provider's Web server (used to service WCTP Client page requests) requires user authentication, use this dialog to specify the user ID and password to be sent to this server application. For more information, see the HTML help for this dialog.
  6. In the fields under Local Performance Settings, configure your performance settings, using the dialog help to guide you. You can customize this information to either provide additional information or control how the Notification Server processes two-way page requests.
  7. If you are planning to connect to one or more paging services implementing the WCTP protocol, you may want to click Advanced to specify your site-specific Internet proxy settings. For more information about this dialog, see the dialog help.
  8. When you have finished configuring your connection and performance settings, click OK.
