To edit the Answer Tree Voice Prompt Menu
When inserting or changing a menu, the Insert Answer Tree data or Change Answer Tree data dialog displays.
The name displays in the Answer Tree window. The answer string is a voice prompt in the form of text or the file name of a prerecorded voice file. In addition to the answer string, you can optionally specify a REXX program to be executed.
Note: When specifying the text for the voice prompt, refer to the Voxmaint utility for the available words in a given voice word library.
