Previous Topic: Configuring an Answer Tree GroupNext Topic: Selecting the Channel Group and Opening the Answer Tree GUI
Configuring a Channel Group
To configure a channel group
  1. From within the Configuration Manager, choose Expert Interface, Notification Services, Voice, Channel Groups.
    The Channel Groups dialog displays.
  2. In the Group Name field, select the ALL group and type over it, entering the name of the new channel group.
    Note: The new channel group cannot be named ALL, NMANSWER, or NMCALL.
  3. Uncheck the Interruptible check box.
  4. Click Create.
  5. Use the Insert and Remove buttons to insert channels into and remove channels from the group available from the card.
  6. Click OK.
