Previous Topic: VOX Client OptionsNext Topic: Configuring the Dialogic Voice Card
Installing the Dialogic Voice Card
Important! The voice card resides in a workstation that uses notification services. Perform the tasks in the section Configuring the Dialogic Voice Card in this chapter only if you plan to install the notification server component on this workstation.
You must install and configure the Dialogic voice card and ensure that it is working properly before you install and customize the notification services function. If you do not plan to use a Dialogic voice card with the CA Automation Point notification services, skip ahead to the section entitled Configuring the Email Feature.
Note: The notification server also supports paging and email; a voice card is not needed for these functions.
