Previous Topic: Addressing the Global Variable EnvironmentNext Topic: Issuing GLV Commands
Setting the GLV Path
You can optionally create a separate directory on your hard disk drive specifically for storing .glv files. After you create this directory, assign the variable GLV_PATH to the directory's path. (From your desktop, click Settings, Control Panel, System, Advanced Tab, Environment Variables, and then Environment.) For example, to store .glv files on drive C in a directory named GLV_VARS, set the variable GLV_PATH to C:\GLV_VARS.
Note: GLV_PATH accepts more than one entry. If you do not create a separate directory for storing non-volatile variables, CA Automation Point stores the .glv files in the %AP_SITE%\Data\GLV directory.
