Previous Topic: Accessing Various Command Environments Through REXXNext Topic: Using the REXX ADDRESS Statement
The following table shows a partial list of command environments that may be available at your site:
Description
AXC
(Default)
CA Automation Point command processors. The AXC environment is the default environment for REXX programs invoked from within CA Automation Point (using the AXCREXX program). For more information, see How to Issue Command Processors in this chapter.
PPQ
Program-to-program queue (PPQ) commands
TNG
The TNG ADDRESS environment provides a REXX-based programming interface to the objects contained in the CA NSM WorldView Repository
GLV
Global variable control commands
VOX
An environment that provides you with the ability to create an executable statement that performs a specific voice processing or voice-related action
OPS
An environment that allows you to communicate with CA OPS/MVS
Note: Product-specific commands may be necessary to activate and deactivate additional environments.
