This section describes how to activate a rules file–such as the sample rules file ACXRULES.rul provided with CA Automation Point–and how to replace the current rules file with another while CA Automation Point is running.
To activate the rules file that you want CA Automation Point to use at startup, specify its name in the Rules Settings dialog in the session definition set. The rules file that you specify takes effect each time you start CA Automation Point.
