Viewing Remote Sessions › Remote Viewer › Securing the Remote Viewer › Security and the Windows Operating System › Adding Users › Adding Groups
Adding Groups
You create new group IDs to associate Windows file permissions with a group rather than just a single user.
To add groups on the CA Automation Point workstation
- Open a Windows command prompt and execute the following command:
mmc.exe %windir%\system32\lusrmgr.msc
- In the Local Users and Groups window, open the Groups folder.
- On the menu bar, click Action.
- From the drop-down menu, choose New Group. The New Group dialog displays.
Note: To add one or more users to a group, click Add in the New Group dialog.
- In the New Group dialog, specify the appropriate information in the following fields:
- Group Name
Specifies the name for the new group.
- Description
Describes the new group.
- To create an additional group, click Create and then repeat steps 2 through 4. If you are not creating any additional groups, skip this step and go to step 7.
- To finish, click Create and then Close. The new group(s) that you created will appear in the Groups folder in the console tree.
