Managing Sessions Using CA Automation Point Windows › Issuing Commands › Issuing a Console Command
To send a console command to a specific session
- Open a window that contains a command area.
- Press the Next Session key (the default key is Alt+N) or click the Next session option from the Cmdarea menu until the command area displays the name of your target session.
- Select the Cmdarea menu.
- Choose Enter command to session.
- Enter the console command in the command area.
Note: You can send only displayable characters. You cannot send key functions such as a PF key, Reset, or Clear.
