Managing Sessions Using CA Automation Point Windows › Issuing Commands › Command Dialog
Command Dialog
Use the Command Dialog as a quick way to enter console commands to a session.
To access the Command Dialog
- Select the session window.
- Choose Command Dialog from the menu, or press Alt+X.
- Enter the command and press OK, or press Submit for sending multiple commands to the same session.
