To change the font selection list, use the CA Automation Point APVIEW/FONTS utility program
Note: The APVIEW /FONTS utilities program and the Remote Viewer (APVIEW.exe) cannot run at the same time. Before you run the APVIEW /FONTS program, verify that the Remote Viewer is not running.
To change the font list for the remote workstation, follow this procedure:
APVIEW /FONTS
The program displays a list of the available fonts that are installed on your workstation. The selection list includes only non-proportional (mono-spaced) fonts large enough to be readable, yet small enough to allow 80 columns of text to display. The fonts listed appear in order, from the smallest to the largest.
Note: Keep in mind that the fewer number of fonts in your font list, the fewer number of keystrokes or Next font menu selections you need to reduce or enlarge a window.
CA Automation Point stores your font selections in the AUTOMATE.fnt file.
