Asynchronous Host Sessions › Asynchronous SSH Sessions › Set Up Asynchronous SSH Sessions
You set up an asynchronous SSH session from Configuration Manager.
To set up an asynchronous SSH session
- From the Session Definition Sets dialog, right-click the Sessions node and select Add Session to create a new session.
The Automation Point Session Definition dialog displays.
- In the Console Type field, select ASYNCH, then click Customize Session Settings.
The Asynchronous Session Settings dialog displays.
- Select SSHCLIENT as the communication device.
- Select other settings as desired, then click OK to save session settings.
For more information on the options available for an asynchronous SSH session, see the Configuration Manager HTML help.
