If the BREAK key is not set to Clear, you can set it temporarily or permanently.
To set the key temporarily, issue the following CP command:
TERMINAL BRKKEY CLEAR
The temporary setting is useful for verifying that your terminal type supports the modified BREAK key.
Note: If an error message displays, contact your z/VM systems programmer for assistance.
To set the key permanently, edit the PROFILE EXEC file, replacing the keyname value in this CP command with CLEAR:
TERMinal BRKKEY keyname
(To use the z/VM XEDIT editor, issue the X PROFILE EXEC command. Be sure to file (save) the modified PROFILE EXEC file.)
Test the new BRKKEY setting by logging off the VM user ID and logging on again. The z/VM logoff causes the guest z/OS operating system to shut down, so you may want to schedule the test.
