Previous Topic: ConfigurationNext Topic: Securing Remote Viewers to Interface with CA OPS/MVS
Remote Viewer Session Windows in Primary Control Mode
When Primary Control Mode is enabled for a given session, the control state for the session connection is displayed in the session window’s title bar. For a detailed description of each status indicator, refer to Remote Viewer Help. From the AP Viewer Msg window, select Help, AP Viewer Help.
Remote users are expected to refer to the title bar to view their current session control status. Given their current session control state, a remote user can initiate actions to change it. From the session window’s Action menu, a user can select options to yield primary control or request primary control. While the request is being processed, the remote user can view the AP Viewer Msg window for Primary Control Mode messages reporting results. For a detailed description of how primary control is transferred among remote users, refer to Remote Viewer Help. From the AP Viewer Msg window, select Help, AP Viewer Help.
