Previous Topic: VOXNM.LOGNext Topic: CAAPNFY.LOG
WEBNM.LOG
This log file is used by the Notification Manager Web Gateway Service (NM Gateway Server) to record activity initiated from the Notification Website. This logged activity includes the following:
For this log file to be used, you must enable notification policy change logging on the NM Website dialog contained within the Configuration Manager application. After you have enabled this change-logging feature, you can adjust the logging parameters (log file maximum size and number of log files to retain) using the same Configuration Manager dialog. Each log message recorded in this file begins with a common prefix, which is formatted into the following fields:
YY/MM/DD HH:MM:SS (user:function)
YY/MM/DD
Specifies the year, month, and day the logged action was recorded by the NM Gateway Server.
HH:MM:SS
Specifies the time (in hours, minutes, and seconds) the logged action was recorded by the NM Gateway Server.
user:function
Specifies the NM login account used to initiate the logged action, and the name of the function currently being performed. If the logged action was the result of an internal system request instead of a login user request, the user name "SYSTEM" is displayed.
