Previous Topic: Amount of Control ExertedNext Topic: Manage Basic Privileges
Basic Privileges Mode
The operations that can be authorized for a specific login user under the Basic Privileges Mode of authorization are described in the following table:
Operation
The specified login user can use the website to:
Notify All Contacts
Send a notification to any contact listed in the Notification Manager database.
Update Personal Schedule
Update schedule and contact information for the contact that is associated with the current login account.
Update Personal Groups
Update the group schedule and group membership information for groups of which the contact is a member. For this privilege, a user is considered a member of the group when their associated contact is defined in at least one group schedule.
View All Contacts
View schedule and contact information for any contact defined in the Notification Manager database
View All Notifications
View the status of all issued notification requests.
Answer All Notifications
Provide an answer for any pending notification request for which the ASK parameter was specified.
Manage All Contacts
Modify schedule and contact information of any contact listed in the Notification Manager database or create or delete any contact in the Notification Manager database.
Manage All Methods
Create, modify, or delete any methods in the Notification Manager database.
Manage All Logins
Create, modify, or delete any logins in the Notification Manager database, including changing the basic privileges of these logins.
In accordance with the overall authorization evaluation process, the basic privileges are evaluated according to the combinatory-granting rule. Authorizations that are granted to subjects from all the basic privileges are combined. As soon as the requested authorization is determined to be granted, the evaluation stops. For example, in the case of updating a personal schedule, an authorization is considered granted if it is granted either through the Update Personal Schedule privilege or the Manage All Contacts privilege.
