Use the following commands to manage the Notification Manager database.
Alters the characteristics of an entity.
Alters the characteristics of a method.
Alters the characteristics of a parameter.
Alters the characteristics of a time block.
Creates an entity.
Creates a login.
Creates a method.
Creates a parameter.
Creates a time block.
Destroys an existing entity.
Destroys an existing login.
Destroys an existing method.
Destroys an existing parameter.
Destroys an existing time block.
Checks the password for an entity.
Lists all the data for one or more entities (except the password).
Lists the time blocks that are active for one or more entities at a given date and time. The list is a tree that can contain any level of nesting.
Lists all the time blocks that forward to a given entity (regardless of the time and date). The list is a tree that can contain any level of nesting.
Lists all the data for one or more logins.
Lists all the data for one or more methods.
Lists all of the data for one or more parameters.
Lists all personal groups for a specified contact.
Lists all the data for one or more time blocks.
Merges a previously exported copy of a database into the current Notification Manager database.
Creates a copy of the current Notification Manager database in a format that can be easily moved to another system.
Adds an entity to the list of entities that are allowed to call in on an item.
Sets or retrieves the answer for an item in the Notification Manager database.
Checks to see whether an entity has been permitted to listen to/answer this item (by a call to NMIADDCALLER).
Retrieves the ask text and tell text for an item from the Notification Manager database.
Retrieves the answers that are specified using the NMFIND ASK parameter (if any) for a notification request item stored in the Notification Manager database.
Retrieves status information about every notification attempt that is made during the processing of a notification request item stored in the Notification Manager database.
Retrieves detailed status information about notification request items stored in the Notification Manager database
Imports a copy of a Notification Manager database.
