A key abbreviation consists of the @ character followed by an alphabetic letter (uppercase or lowercase), a digit, or the character itself. For example, the abbreviation for the Enter key is @E. The abbreviations are mnemonic; that is, they correspond as much as possible to the actual name of the key. For example, @C is the abbreviation for the Clear key, @A is the abbreviation for the Alt key, and so on. The following table provides a comprehensive list of valid key abbreviations.
Note: When you press a shift key (such as Alt) in combination with another key, the meaning of that key changes. For example, the Alt+Clear keys constitute the Test key; to send the Test keystroke, type @A@C.
The following is a list of key abbreviations.
Abbrev. |
For Key |
Abbrev. |
For Key |
Abbrev. |
For Key |
@u |
PageUp |
@PgUp |
@v |
PageDown |
@PgDn |
@A |
ALT |
@V |
Cursor Down |
@c |
PF12 |
@B |
Backtab |
@X |
Reserved |
@d |
PF13 |
@C |
CLEAR |
@Z |
Cursor Right |
@e |
PF14 |
@D |
Delete |
@ character |
@f |
PF15 |
@E |
ENTER |
@0 |
Home |
@g |
PF16 |
@F |
Erase EOF |
@1 |
PF1 |
@h |
PF17 |
@H |
Help |
@2 |
PF2 |
@i |
PF18 |
@I |
Insert |
@3 |
PF3 |
@j |
PF19 |
@K |
Copy |
@4 |
PF4 |
@k |
PF20 |
@L |
Cursor Left |
@5 |
PF5 |
@l |
PF21 |
@N |
New Line |
@6 |
PA6 |
@m |
PF22 |
@Q |
Finish (Quit) |
@7 |
PF7 |
@n |
PF23 |
@R |
Reset |
@8 |
PF8 |
@o |
PF24 |
@S |
Shift |
@9 |
PF9 |
@x |
PA1 |
@T |
Tab |
@a |
PF10 |
@y |
PA2 |
@U |
Cursor Up |
@b |
PF11 |
@z |
PA3 |
