Previous Topic: Keys Mapped to Terminal OperationsNext Topic: Key Operations for Asynchronous Console Sessions
Key Operations Specific to CA Automation Point
The following key operations control functions specific to CA Automation Point only:
Operation
What It Does
Enhanced 101-keys Mapped to Operation
CONNECT
Issues a connect request for the session.
For more information, see the discussion of SESSCNTL CONNECTION in the Command and Keyword Reference Guide.
CMD_HOST
Lets you send console commands to specific terminal emulator sessions. (This operation does not work from a REXX program.)
User-definable
DISCONNECT
Issues a disconnect request for the session.
EXECUTE
Executes a script from the current session window. (This operation does not work from a REXX program.)
User-definable
FONT_LARGER
Selects the next larger font in the current window and increases the window size proportionately
Ctrl+ Right Arrow
FONT_SMALLER
Selects the next smaller font in the current window and decreases the window size proportionately
Ctrl+ Left arrow
NEXT
Switches to the next session controlled by CA Automation Point. (This operation does not work from a REXX program; it only works in the red command area.)
Alt+N
PAUSE
Tells CA Automation Point to pause automation by releasing control of automated sessions. (This operation does not work from a REXX program.)
User-definable
SCREEN_LAYOUTS
Opens the Layouts dialog. For more details, see the section Layouts
SCREEN_LOAD
Loads the current active layout (if it exists). For more information, see the section Active Layout.
SCREEN_SAVE
Saves the current layout under last active layout (if it is set). For more information, see the section Active Layout.
QUIT
Closes the specified window (but does not halt automation of the session in that window)
User-definable
WIN_NEXT
Jumps to the next CA Automation Point window
Alt+J
