Managing Sessions Using CA Automation Point Windows › Using the Automation Point Desktop › Layouts › Working with Layouts
To manage your layouts, select Layouts from the Action menu. The Layout dialog displays, listing currently saved layouts.
- To save a new layout, select *New*, then click Save. You will be prompted for a name for the layout.
- To save your current layout to an existing name, select an existing layout and click Save.
- To load previously saved layout, select the layout name from the list and click Load.
- To restore default window positions according to the Sizing setting in the session definition set, select *Empty*, then click Load.
- To rename a layout, select the layout name and click Rename. You are prompted to enter the new name.
- To delete a layout, select the layout name and click Delete.
- To exit the dialog, click Close.
