Previous Topic: TN3270 and TN5250 ConsiderationsNext Topic: The TN5250 Status Line
The TN3270E Status Line
The Status Line (or OIA - Operator Information Area) is the line at the bottom of a TN3270 session where status information about the session displays.
The meaning of each field on the TN3270E Status line (OIA) is as follows:
Column 1-3: Connection status indicator:
4B
A TN3270E connection has been established.
NVT
NVT-mode connection has been established. This generally occurs while the session is first initialized.
N
The session is not connected.
Columns 10-17: System status indicator:
X SYSTEM
Input from the session is inhibited (for example., the host system is busy)
X ?+
Input from the session is inhibited (for example, the keyboard is locked)
XPROG505
XPROG572
A TN3270 command (SBA, RA, or EUA) contains a screen address pointing outside of the current screen.
Columns 37-39: Security indicator.
SSL
The session has been configured with SSL enabled.
<blank>
The session has not been configured or configured without SSL enabled.
Columns 42-53: Terminal type indicator.
Columns 56-71: LU/Device name. This can be either the LU/device name assigned by the TN3270E server for this session during protocol negotiation, or the LU/Device Name specified in the session definition using Configuration Manager.
Columns 74-79: Cursor position indicator.
rr/ccc
Row (rr) and column (ccc) number of current cursor position.
Note: On a model 5-type session, the cursor position indicator starts at column 125.
