To manually suspend control of an AS/400 system, issue this command from a red command area in CA Automation Point:
SUSPEND sysname [nn] [mm]
Specifies an AS/400 system, tag, or group name to be suspended.
(Optional.) Specifies the number of minutes before control of the AS/400 systems should be resumed.
(Optional.) Specifies the number of minutes that the invocation of this routine has been delayed. This is normally specified only if called from the message rule for AXC0000 (the voluntary suspension message), and represents the number of minutes the AXC0000 message has been waiting in the alert queue. The suspend time is adjusted to compensate for this delay.
