Previous Topic: Environmental Variables for AS/400 ManagerNext Topic: Monitoring AS/400 System Status
Rules Keywords Used for AS/400
You can use all CA Automation Point rules keywords for AS/400 with these exceptions:
OSCMD
Using this keyword can cause unpredictable results. Instead of OSCMD, use the supplied REXX program AS400MRP to issue responses to messages, or write REXX programs to issue commands to the AS/400 MAIN menu command line.
REPLY
Using this keyword can cause unpredictable results. Use REXX programs as detailed for OSCMD.
SCRIPT
Instead of using SCRIPT, invoke scripts from REXX programs to ensure the integrity of communications with managed AS/400 systems.
SESSCMD
For integrity reasons, use this keyword only in REXX programs.
