Previous Topic: AS/400 Manager Application CommandsNext Topic: Connecting CA Automation Point and AS/400
AS/400 Manager Terminology
The section that follows includes terminology that you should become familiar with before using AS/400 Manager.
alert primary focal point
Identifies the AS/400 system services control point, from which the AS/400 Manager application reads alerts that other AS/400 systems have forwarded to the focal point.
alert session
Identifies a CA Automation Point session processing alerts from a local AS/400 system that is an alert primary focal point. Each alert session (you can have more than one) is signed on automatically to its AS/400 system via a REXX program called AS400CTL.
local AS/400 system
Identifies a directly connected AS/400 system. A local system can be connected using a TN3270 session. Physical location has no bearing on whether a system is considered remote or local.
remote AS/400 system
Identifies an AS/400 system that is accessed indirectly through another AS/400. Remote systems can be connected using either of the following:
