Previous Topic: Determining HAF Message NumbersNext Topic: HAF Error Messages
Samples for Determining HAF Message Numbers
As described earlier, the mm portion of message number HAFImmnn is associated with HMC event message types. The following samples show how to determine HAF message numbers for an IBM HMC.
This sample shows 14 different event types that are listed in IBM manual SC28-8141-09. The following names and hexadecimal values of the event types are listed in numeric order with the associated HAF message number included at the end in parenthesis:
Other code levels for an IBM HMC could number these event types differently or could have more or fewer event types. In those cases, the HAF message numbers would change accordingly, but you would use the same process to determine what they should be.
Keep in mind that the event portion of a HAF message contains the event type for the message. For example, the third word of a HAFI05nn message for the previously mentioned level of IBM HMC would be ACTIVATE_PROF_CHANGE.
