Previous Topic: NM Attributes DefinitionsNext Topic: How You Extend the Schema
NM Object Class Definitions
The following table shows the objectClass definitions used for the Advanced Permissions.
ObjectClass and OID
Description and Attributes
Structure
apnmLoginRights
apnmoid.2.1 (1.3.6.1.4.1.791.2.10.5.3.2.1)
Defines entries representing the NM login user. Contains attributes that specify the NM authorization permissions
Mandatory attributes:
commonName
Optional attributes:
nmLoginName
nmLoginTeam
nmNotifyContacts
nmReadContacts
nmUpdateContacts
nmNotifyContactTeams
nmReadContactTeams
nmUpdateContactTeams
Multiple values may be set for any of these attributes.
This is a structural object subclassed from the top.
An apnmLoginRights entry may be placed under an organizationalUnit entry in the directory.
For more information on the directory hierarchy, see the section How You Extend the Schema.
apnmLoginPerson
apnmoid.2.2 (1.3.6.1.4.1.791.2.10.5.3.2.2)
Defines entries representing NM login user. Use to construct the NM login team branch in your directory.
commonName
nmLoginName
Multiple values may be set for either of these attributes.
This is a structural object subclassed from top.
An apnmLoginPerson entry may be placed under an organizationalUnit entry in the directory.
apnmContactPerson
apnmoid.2.3 (1.3.6.1.4.1.791.2.10.5.3.2.3)
Defines entries representing the NM contact user. Use to construct the NM contact team branch in your DIT.
commonName
nmContactName
An apnmContactPerson entry may be placed under an organizationalUnit entry in the directory.
Note: A special "everyone" contact name can be used for attributes that specify permissions for an NM contact user. These attributes include nmNotifyContacts, nmReadContacts, and nmUpdateContacts. This special value is recognized internally by CA Automation Point, and can be used to indicate the broad permissions a login user may have.
