Notification Manager provides two built-in login names that you can use initially to set up your site, and use as a basis for subsequent transitions. These are NmAdmin and NmGuest. These names can be used both for authentication and authorization.
Note: For more information about authorization, see the section User Authorization in this chapter for details on authorization.
The built-in login names are described in the following table:
Login Name |
Description |
Privileges |
NmAdmin |
Administrative login name. Regardless of the authentication mode, the Notification Website checks the internally stored password to confirm this user. |
When confirmed, this user can perform all operations available within the website. |
NmGuest |
Guest login name. Regardless of authentication mode, the Notification Website checks the internally stored password to confirm this user. |
When confirmed, this user can perform authorized operations within the Notification Website. NMGuest has a set of privileges that are assigned by default. You can modify this login name through the Notification Website. |
Important! We strongly recommend that you change the passwords of the built-in login names before you publish the website, and allow only limited access to these accounts. The built-in logins are especially necessary during startup, but if used improperly, they could endanger your security measures.
