The following list describes Notification Manager method programs.
Provides a means for NMFIND to notify a person or group using the local email system.
Provides a means for NMFIND to notify a person or group through speech using the TCP/IP network.
Provides a front-end to the NMMAIL program. NMFIND uses this command to notify a person or group by initiating an alphanumeric page using the email system.
Provides a means for NMFIND to notify a person or group via the NET SEND command using the TCP/IP network.
Allows NMFIND to notify someone using a TAP alphanumeric or numeric pager.
Allows NMFIND to notify someone using a 2-way messaging device. If a question was specified, the user may also respond to the question by replying to the page request.
Allows NMFIND to notify someone through a TAP alphanumeric or numeric pager. It differs from NMPAGE in that the REXX code talks directly to the modem instead of using the ADDRESS VOX PAGE command to perform the page. NMTAP supports the batching of pages (that is, sending multiple pages to a paging service with a single phone call). NMTAP is designed so that you can easily modify it to support a different protocol than TAP. For more information, see the NMTAP.txt file in the Distrib directory.
Allows NMFIND to notify someone using a voice card and, optionally, ask them to make a selection from a set of options.
Note: For more information, see the Command and Keyword Reference Guide.
