Previous Topic: Using Method TypesNext Topic: Using the MTUP Parameter on the NMFIND Command
Specifying Method Types Using the Notification Website
If you are using the Notification Website to send notification requests, you can use the Acceptable Types of Notification area of the Send a Notification page to select which types of notification methods should be considered for use on a particular notification request.
