The CA Automation Point AXCREXX program activates the AXC environment and makes it the default environment. The AXC environment allows you to issue CA Automation Point command processors from your REXX programs.
All REXX programs invoked from within CA Automation Point—for example, from rules or from a CA Automation Point command line—run under AXCREXX (and, therefore, access the AXC environment by default):
"command operands"
For example:
"SETVAR REXX_MESSAGE (REXX SENT THIS MSG)"
ADDRESS AXC "command operands"
For example:
ADDRESS AXC "SETVAR REXX_MESSAGE (REXX SENT THIS MSG)"
