The following table shows a partial list of command environments that may be available at your site:
Environment |
Description |
AXC |
CA Automation Point command processors. The AXC environment is the default environment for REXX programs invoked from within CA Automation Point (using the AXCREXX program). For more information, see How to Issue Command Processors in this chapter. |
PPQ |
Program-to-program queue (PPQ) commands |
TNG |
The TNG ADDRESS environment provides a REXX-based programming interface to the objects contained in the CA NSM WorldView Repository |
GLV |
Global variable control commands |
VOX |
An environment that provides you with the ability to create an executable statement that performs a specific voice processing or voice-related action |
OPS |
An environment that allows you to communicate with CA OPS/MVS |
Note: Product-specific commands may be necessary to activate and deactivate additional environments.
