Previous Topic: Daylight Savings TimeNext Topic: Writing Message Rules
Pictorial Time Rule Examples
This section contains illustrations that will help you to better understand how CA Automation Point processes time rules.
Note: All clocks are 24-hours clocks. The times noted on the outside of the clocks indicate when time rules are scheduled to execute.
Scenario 1: The time is set back from 02:00 to 01:00.
If Enable Clock Change is checked:
If Enable Clock Change is not checked:
Scenario 2: The time is set ahead from 01:00 to 02:00.
Enabling Clock Change does not affect forward moves.
Scenario 3: The time is set back from 00:30 to 23:30.
Rules processing resumes normally at 00:30. Therefore, the 02:00 rule executes at 02:00 the same day.
Scenario 4: The time is set back from 06:00 to 03:00.
