Previous Topic: Keywords for CA NSM (Event Traffic Controller)Next Topic: How Rules Are Processed When More Than One Rule Applies to a Message or Command
How CA Automation Point Processes Rules Keywords
When processing a rule, CA Automation Point always executes keywords in this order:
type_keyword [conditional_list][output_list][action_list]
type_keyword
Specifies the type of rule. Specify one type keyword per rule at the beginning of a rule. Use one of these keywords:
conditional_list]
Specifies the restricting conditions for the rule. Specify each conditional keyword only once in a single rule. The rule condition keywords execute in the order in which they appear in the rule. You can use these keywords:
output_list
Sets output attributes in CA Automation Point. Specify each output keyword only once in a single rule. The rule output keywords execute in the order in which they appear in the rule. You can use these keywords:
ALARM
NOLOG
COLOR
NOPRINT
DISPLAY
PREFIX
HILIGHT
PRINT
LOG
REPLY
LOWLIGHT
REWORD
NOALARM
SUPPRESS
The rule output keywords set output attributes that can be changed by subsequent rules. When a rule contains one or more output keywords, the conditions they set remain in effect until CA Automation Point executes that rule and all other rules referencing the same message ID or time value.
action_list
Specifies tasks for CA Automation Point to execute. These actions occur or queue for execution immediately and cannot be undone by a subsequent rule. You can specify action keywords multiple times in a single rule. The action keywords execute in the order in which they appear in the rule. You can use the following keywords:
ALARMSAY
SCRIPT
DOM
SESSCMD
DOSCMD
SET
OSCMD
WTO
PPQWRITE
WTXC
REPLY
XCCMD
REXX
