Previous Topic: Specifying Table Columns for Your MessagesNext Topic: Message Color Mapping
Specifying the Color of Your Messages
Web MV allows you to specify or change the colors of your messages. This feature may be helpful to you for message organization, viewing, and so on, particularly if you are viewing a large volume of messages.
To specify or change the background color of your messages
  1. From the Options menu on the Web MV main window, select Colors.
  2. Select Table Colors
    The Table Color Selection dialog displays
  3. Select the Table Background from the Color Properties drop-down list for the desired message type.
  4. Click the corresponding Change button.
    The specified Background Color Selection dialog displays.
  5. Select a new color for this field, then click OK.
By default, the color scheme selected from the Table Color Selection dialog applies only to the currently monitored CA Automation Point session. To apply the color scheme to all sessions available to you on the selected CA Automation Point server, select the Apply to all sessions check box at the bottom of the Table Color Selection dialog.
For more information about the fields in the Table Color Selection dialog, see the Web Message Viewer HTML Help.
